I am trying to get a tachometer for my 1977 evenrude 70 hp. I found a teleflex 0-7 k , for outboard and 4 stroke but not for force eng. the question is, is a force engine a type or a brand. I never heard of it.
As suggested try again.Poorly chosen subject most who check in will be prepared to help with a Force motor even though you listed a Force subject in the Evinrude forum. But it does appear you need help with Evinrude or possibly
a tach.If you check your post I think you will see you all you did was tell us you found a tach.no indication of a model number,new/used a or specifically what your question is.
Thank you, after I posted this yesterday I was reading a decustion about a tachometer problem and changed my mind about changing the tach. What my problem is last summer when i was out with that boat the tach started to read double of what it should. I mite have allready fixed the problem.
