i was out the other day with alot of people on the boat and was running the engine at about 4K. out of nowhere, it comes out of gear. i bring it back to neutral and try to put in slowly back into forward ( nothing ) then reverse (nothing ). shut it down and tried again (nothing ). got towed in and tried it the next day ( nothing ).........it runs fine and the throttle works fine, but will not go into gear. what is the most likely problem? do they still use shear pins in these things? i have not pulled the lower unit, just trying to get as much trouble shooting done as possible before i start taking stuff apart. thanks in advance. it is a 1989, cables are fine and i have a 1991 120hp avail for parts ( assuming the lower units are the same )
