force 125 1988 starter problem
matthewfb
have a problem the motor will not start. the starter spins up but the wheel will not move up to engage the flywheel an suggestions.
Jiggz
Re: force 125 1988 starter problem
Can you move the starter pinion gear up manually? You should be able to spin it and move up the shaft as it moves. through the helical thread on the drive shaft. Sometimes the spring which pushed is back gets caught thus the gear gets stuck and will not slide up. A light grease will prevent this from happening.
jerryjerry05
Battery cables hooked right?
Load test the battery.
Jiggz
And you posted the starter was spinning except the pinion would not move up?
matthewfb
just installed dual batteries do i run the ground wires to both or just one battery. does the engine and fuel pump ground or to the starting battery only?
also running one voltage guage should I connect that to the starting battery
foodfisher
Head over to the electrics, electronics,trolling motors forum. Tons of diagrams there.
