Re: Force 120 Overheats
The overheat buzzer tells me it overheats.
When it overheats I can't keep my hand on the head for more than a couple seconds. Prior to that, I can hold my hand on it for around 5 or 6 seconds.
I took it to the lake today and tied off to the dock and ran it. After about 15 minutes at idle, it overheated again. I haven't tried moving around yet because I don't want to get too far and have to limp it back to the dock. I did notice that I have an exhaust leak into the cowl. It ran fine with the cowl off but as soon as I put it back on, it overheated about 5 minutes later. Maybe the exhaust is leaking back into the carbs and overheating it? Also, I got home and taped off the muffs and noticed that I have water shooting from weep holes on either side of the lower unit and a very heavy stream of water flowing from the prop.
I went to do a compression test and found my gauge is busted so I have to run down to Autozone and rent one of theirs.
And if things weren't bad enough, I found one of my spark plug ends broken off so I have to track one down. In my neck of the woods, it's not easy to find the L76V's.
With that new info, any more suggestions?
