if it's white i would not use it, that's what they use down here reg styrofoam
From Wikipedia, the free encyclopedia
http://en.wikipedia.org/wiki/Polystyrene#Expanded_polystyrene_foam
Expanded polystyrene foam
Close up of expanded polystyrene packagingExpanded polystyrene foam (EPS) is usually white and made of expanded polystyrene beads. Familiar uses include packing "peanuts" and molded packing material for cushioning fragile items inside boxes. It is commonly packaged as rigid panels (size 4 by 8 or 2 by 8 square feet in the United States), which are also known as "bead-board". Thermal resistivity is usually about 28 m?K/W (or R-4 per inch in American customary units). Some EPS boards have a flame spread of less than 25 and a smoke-developed index of less than 450, which means they can be used without a fire barrier (but require a 15 minute thermal barrier) according to US building codes. A growing use of EPS in construction are Insulating concrete forms.
[edit] Extruded polystyrene foam
Extruded polystyrene foam (XPS) has air inclusions which gives it moderate flexibility, a low density, and a low thermal conductivity.
Extruded polystyrene material is also used in crafts and model building, particularly architectural models. Because of the extrusion manufacturing process, XPS does not require facers to maintain its thermal or physical property performance. Thus, it makes a more uniform substitute for corrugated cardboard. Thermal resistivity is usually about 35 m?K/W (or R-5 per inch in American customary units).
Trade names for XPS include "Styrofoam", "Foamular", "Greenguard" and "Foamcore". ("Styrofoam" is often also used as a generic name for all polystyrene foams.)
joe
