harrison20002
- Aug 26, 2001
- 222
I have an old {?} 7 1/2 hp Sea King. I went to install points and condenser. When I reinstalled the Flywheel I tightened the nut down and the flywheel was bound up. Thinking I had put the key into the keyway wrong, I took it off and put the key in the keyway up against the top of the Flywheel, tightened it down again and the same thing. I didn't notice a spacer under the crankshaft where the Flywheel sits. Can someone tell me where I went wrong? Thanx in advance for any help with this, Hal
