Re: First ride in the boat - had to paddle back
I referred you to Frank's posts as he addressed the issue of removing a stuck flywheel.
Here is my suggestion.
Assuming you are using the puller that has three bolts into the wheel and the center screw applying pressure on the crankshaft. Set up the puller in position but not tight. spray crank/wheel junction with Deep Creep or Kano Kroil and heat with a hair dryer. Crank center screw and put pulling pressure on wheel.
Spray and heat several times over 48 hrs. Next, rap center screw with 3lb masons hammer. Try tighening screw somemore and rap screw again.
This procedure usually works.
If it does not, you can try heating the wheel/crank junction with a propane type soldering iron. DO NOT USE A FLAME. Also make sure all gas is out of carbs before doing this.
Once it is heated, take dry ice (available in most supermarkets) and, with a glove, apply to shaft. The idea is the aluminum wheel will expand from the heat and the shaft will shrink from the cold. This is hard to do with a puller on it but I have done it in the past with other flywheels.
Regards,
John
Crank the
