richardbrown67@yahoo.com
- Oct 31, 2010
- 37
Thanks to this forum I'm moving ahead.
Expert, humor me if you will....
Here are the facts:
1980 Johnson 70hp 3 cyl.
Starts easily, runs well for 10-15 mins, then bogs down and finally quits
No spark on #3 cyl after motor misbehaved. Spark good on 1 & 2.
Swapped coil wires #3 with #2.
After the swap, #2 cyl had no spark, while 1 & 3 had good spark. A-ha moment.
Swapped coil wires back to original configuration - again, no spark on #3, spark good on 1 and 2, as before.
SO - I think all three coils are okay. A local mechanic told me it is very likely that the problem is a faulty power pack, but it could be a faulty timer base.
All the electrical components look original, so they're 30 years old.
I put in new spark plugs, L77Jc4, according to a manual.
So - at this point - if it were you -- would you install a new power pack in hopes of solving the problem, or are there other steps to take? What about the timer-base?
Thanks, everyone.
Richard
Here are the facts:
Thanks, everyone.
Richard
