Whelp, after sanding and time constraints, I decided to just brush 2 coats and sand it flat. I picked a color match off a swatch which never matches perfect, but we'll see how good it looks once I feather the edges. I played with adding a few tints I had from a polyester gelcoat patch kit, and ended up getting a bit closer which was a small win. If I really dont like it, I'll just sand it back and maybe call Bayliner as they can assist with a either a color code, or a dealer match. I probably used 8 oz painting this one.
I catalyzed at 2%, and once it sat for an hour a tacked up I wiped on some PVA to create the cure coat, and will let it sit until tuesday before sanding. I have a test piece I can compare with so I won't jump the gun!
Pics below.
