1986mariner150
- Mar 13, 2004
- 142
Hello everyone: the time has come for fiberglass work on my 2 boats, first the easy one, My bass boat has what looks to be about a 1 foot square soft spot around the drain hole in the floor, all the material around this spot still looks orange but that spot is blackish. I thought I would cut back into the good stuff a couple of inchs, scrape out the foam, cut a peice of plywood to close fit the hole, then resin in a peice of mat first then wood then mat. As for the foam i thought i would cut a peice of pvc a little larger than the hole, drill 4 holes, after installation i want to shoot great stuff expanding foam through the holes. Does this sound right? <br /><br />The other project is more involved; cabin crusier needs a transom and floor, my main question involves the transom. I have read many posts here and all i have seen have cut the transom from the outside. I went to the fiberglass repair shop to purchase materials and mentioned my game plan on this and he said absolutly do not cut the outside of the boat. Just when I thought I had things pretty much figured out i was blown out of the water. How do you do this from the inside out? We did talk about demolishion and I mentioned the chainsaw and he showed me his, I am with evin it seems to be the right tool for the job. I am now leaning towards pouring in the transom, concern here is its inboard/outdrive so what do I do about the hole?
