MR nova @#25
- Dec 7, 2011
- 144
1. My new transom is in, My plan is to use a layer of heavy matt and a layer of heavy Woven to cover the transom. Will that be enough?
2.Its looks like the engine compartment is a separate section of gelcoted fiberglass that was bonded/glued to the bottom of the boat. Its a little harder than Bondo I'm sure it 5200 or something close to it. Between the bottom of the boat and the engine compartment this stuff was about 1/3in thick. It took a couple hrs. to grind it all out( glade I did found some bad spots under all the goop):listening_headphone.
My question is: Do I need to do anything to compensate for this missing glue, Or should I just add a extra layer glass and drive on!?
