I had my 78 Johnson 140 out on the stand today to test run it after a whole bunch of work. The motor ran a year ago when I bought it but needed the power head gasket changed and some maintenance work done. The motor started sputtered, died and would not start. Subsequent troubleshooting showed no spark. Resistance check in the Stator shows out of speck and I get 0 volts DVA to either ignition pack connector with the packs unplugged. Is this just a fluke or could there be some other issue that caused this?
I have no idea how the motor ran under load as I bought it with a junk boat and never ran it under load. The way it ran on the muffs made me feel it needed carbs cleaned and when I looked at the plugs they were not colored uniformly (suspected carbs as well) For all I know the stator had issues and was limping along when it finally gave up the ghost this morning. At 225 for a replacement I'd like to guard another failure.
