Purduebarry
- Sep 29, 2005
- 378
I fully winterized, fogged etc. last October. Everything ran strong when I put it up for the winter. I started to repair a small soft spot on the deck...way too late in the season...and...now I'm facing a transom repair . <br /><br />I'm becoming concerned about too much time out of water, running the engine, gas etc. The engine/drive are still in and I'm sure the boat would be fine up if I went for a run then pulled everything for the final repairs.<br /><br />So, should I...<br />1) Dewinterize, put it in the water, run out the old gas etc.<br />2) Put it on muffs or tank, run it on land, just to get everything moving.<br />3) Prepare the engine for an extended shut down, i.e. pull plugs, oil the cylinders, drain gas, etc.<br />4) Don't worry about it, the winterization should hold it over.<br /><br />I expect to have this thing repaired and back on the water as soon as possible but it might take a few more months. If I do nothing (option 4) when should I become concerned? Will another few months be a problem?<br /><br />I know this is not the ideal, but the rot and repairs exceeded my expectations and I want to make sure I don't create additional problems.
