Re: Exhaust Side Water Jacket question
I gotta agree with Bob here (cold up there huh Bob?...rainy here at salty sea level..mountains getting nailed..I 90 over the Cascade pass been closed for on/off 4 days..getting FEET, not inches!)..anyway..gaskets are designed to conform to dips/roughness, etc. for sealing. Meant for bare, clean metal...Putting anything in the way defeats the purpose...
Yeah, well, I have batted that statement around all my life and I think carburetors are the only places I used dry gaskets. I use an appropriate sealer and have never had a problem. I may not have fixed 1000 engines in a repair shop, but I have kept all my equipment (and I've had a lot of it) running all my life with only a couple of trips to the shop to have something done I couldn't or wouldn't....most of which since I retired and got lazy.
One thing I like about adhesives is that they hold the gasket in place while you are attempting to get the thing together. Try leaning over the fender of a 454 Chev station wagon with a 75# head in your hand trying to stab it and get it right without creasing the gasket, by yourself.
I have actually had problems with dry head gaskets and never had a problem since using Kopper Koat which was made specifically for head gaskets. I know that one of the reason's adhesives are not recommended is that the sealer becomes part of the seal and the mfgr has no idea what type of sealer you are going to use so they must figure the best advice is put it on dry.
Problem you have with raw aluminum on dry gaskets is that you are relying on the gasket to seal the alum against the environment. Obviously it doesn't or there wouldn't be corrosion on my alum parts when I take things apart. I guarantee you, when you restore a 20 year old Mercruiser, you have holes that gaskets cannot possibly seal without some type of sealer. BTDT
Matter of fact, in Big B's picture, looks like somebody put adhesive on that gasket. If it were dry alum against a waterproof gasket, what is the mechanism whereby the gasket material we see sticks to the alum. Also, do I see corrosion on that cover? Looks like it along with the stuck pieces of gasket.
Carburetors are a good example. The carb castings are alodined and put together dry. When you dismantle a carb, the castings come off the gaskets clean to the point that in a tight you can even reuse the old gasket. BTDT
But, like motor oil and beer, to each his own.
Mark
