Re: Exhaust bellows delete
I picked up an '84 Rinker with a 3.0 and when the PO did the bellows a couple of years ago he left out the exhaust bellows. He claimed that he read somewhere that it picked up some HP/TQ. I have been reading on 3.0 engines for some time, and not come across that. Has anyone else?
Mercruiser went to a tube on the BIG BLOCK engines in order to help stop back pressure, but they did not eliminate it.
The bellows (or tube) is used to direct exhaust through the prop, without the bellows, you do not have the flow through the prop the props were designed to run with.
Yeah. When I got my 21' FourWinns from my brother and it still had the 460 King Kobra installed, I was decided to replace both the main bellows and the exhaust.
The exhaust was missing! When I asked my brother about it he said what bellows? It was switched from thru-hull exhaust to a Capt's-Call about 15 years before I got it.
The installer had not installed an exhaust bellows when he installed the y-pipe and diverter valves.
It ran that way for all those years (with no ex bellows) and no one noticed.
It was a bit noisier (compared to using a bellows) , but that was about it.
Even switching from "thru-drive" to thru-hull (with the switch), although it was REALLY LOUD, made virtually no performance difference.
It just irritated bejeebies out of everyone else!
