Evinrude XP 150 Ignition Problems
vaughan376
Hi guys, I'm new to this site, and have a lot of questions. I will try to make this as short as I can. Problem: 1989 Evinrude XP150 model# E150STLCEM with ignition problem.Two years ago motor quit -not firing. Local mechanis said bad power pack; replaced-- back on water--six fishing trips--down again. Local mechanic sent me to another mechanic who replaced what I call the trigger (part under flywheel with six firing points).Back on water for several trips. Boat sat for 3 months during winter, No batteries hooked up. Last spring developed firing problem again, firing on 4 cylinders. 2 not firing #3and #5 cylinders. I tested spark by removing all plugs from engine and made sure they were grounded to block. Out of curiosity I put the old power pack-(one with no fire at all)- back on motor, and now have fire on all cylinders except #6.Replaced pack back to newest one--still not firing on #3 and #5. Moved primary wire going to #1 coil down to the #3; and #3 primary wire up to #1. Now getting fire on #3 but not on #1.I figure coil for #3 must be good--would you agree? If the coils seem to be OK do you think I will have to replace power pack again? Is there something that I am doing wrong that is causing the packs to go out or is this common? Should I unhook the battery to the engine or is it OK to leave it hooked up? Any info on ways to test ignition would be greatly appreciated. :confused:
Mod2
Re: Evinrude XP 150 Ignition Problems
Welcome Vaughan...I'm going to move your post to Johnson/Evinrude repair forum. You'll get quick anwers there.
OBJ
Hi ya' vaughan....welcome to iboats.<br /><br />Start by taking a look at all grounds. Check that the coil grounds are clean and the pack grounds are solid and clean.<br /><br />Check all your amphenol (these are the rubber plugs that connect the wires together) are clean and no pins are broke. Check on the motor and from the pack.<br /><br />Look for general stuff like wires that may be bare and stuff like that.<br /><br />Yea...sounds like the pack but checking for other causes is always a good idea. By the by...was that a new pack the wrench installed?<br /><br />Also a good idea is to get a service manual for your engine. OEM prefered....this can be ordered from your local dealer. <br /><br />Keep us posted.
vaughan376
Thanks OBJ will check grounds, mechanic is good friend of mine, he told me he thought it was pack. I went to dealer and bought new pack and installed myself.When this happened second time we were both "stumped", he made a few calls and came up with liscened mechanic who replaced trigger. I don't have a manual but will get one. Thanks again and good boating to all! JV.
clanton
Have someone check the stator output at cranking rpms plugs in, and check again at 3/4000 rpms. After checking the magnets in flywheel. When running at high rpms, engine should be on a dyno or in water in gear.
