Re: evinrude mate 1 1/2hp
Sir:
On the 9.5 hp motor of the same vintage (they're very much alike), the fill procedure is different than you'd expect. Remove the drain plug and what seems logically to be the fill plug. Instead, fill from the lower plug, they want it done that way to prevent air pockets from forming in the lubricant as it is added. Side note, don't use automotive gear lubricant, it tends to foam, that's ok in a rear axle, there's plenty of room for the foam. It is not ok in a confined gearcase on an outboard, there is no place for the foam to migrate, you can easily pop the seals. Use only Marine grade gearcase lubricant.
Gary
