I just bought my first boat. A 98 Aquasport 175 w/ 98 Evinrude 90hp SPL. I checked the compression on it, and all cylinders read 120-125 psi. The water test went flawless, so I made the jump and bought her.
The motor had a 15" prop on it, with some damage to it. At WOT, I was running around 5000-5500. When I brought the prop in for a refurb, I was talked into a 17" prop. I figured no big deal because I have read others running with a 17" on the same package.
So I took the boat out today, and she ran awesome, except my tachs were reading 6500-7000. I figured WTF? How could that be? If anything my RPMs should of gone down with a more aggressive prop, right? The way the tach was bouncing/floating around, the fact that it would drop whenever I hit the trim (but I certainly didn't hear the motor dropping), and the fact that the motor didn't sound like it was screaming, I chalked it up to a inaccurate tach.
Well, after about a total of 20minutes of WOT (broken up by "no wake zones") I went to pick the wife up at the ramp. After she got in, I noticed the motor wasn't running right at idle. It was all jerky/sort of sputtery, and wouldn't go over 3k at WOT. To make a long story short, I checked the plugs, and one of them was closed shut (no gap at all). I thought I found the problem, except when I checked the compression in that cylinder, it now only reads 90psi.....:facepalm: As an FYI, I did hear something "drop" in the motor when I was idleing up to dock to pick the wife up. Almost sounding like a screw fell or something.
So, why would my RPMs be higher with a more aggressive prop, and what could of came in contact with the plug to close the gap, and what is the corelation to loss of compression.
Thanks for you time,
Ken
Ken
