I can find a lot of members here, there have/had the same problem as mine.<br />The Evenrude 60 HP VRO from 1990 wont idle, when I put in water, becose of the back-pressure on the exhauste.<br />I have cleaned the carburators, new plugs, clean tank, new gas, new hoses and handpumps, there is no leaking from VRO-pump, Powerpack is OK, there is spark on all cyl. Comp.pressure is 111, 115 and 116 PSI. All links and cabels has been adjusted according to the manual. The fiber-cam-follower is in center of the mark at the cam (when in neutral), and the clearens between fiber-cam-follower and the cam is 0,2mm. And in that pos. are all. the caburator totaly closed.<br />I have adjusted all. caburators at the low-speed needle valve according to the manual. But still the idle speed is far to low (5-600 rpm when I have the motor out of water, connected to a water-hose). If I start to adjust the idle speed at the idle adjustment screw on the lever for spark control, then I cant keep the clearens between fiber-cam-follower and the cam at 0,2mm. Am I doing some thing wrong in my adjusting ?
