csisommout
- Nov 17, 2008
- 231
I have Evinrude 50 hp With serial # G02535055, Model # VE 50bELESR. won't above 1500 RPM, It is cutting off try to die. Have done Commpression checked 122 Top cylander, 119 bottom cylander, spark checked at 7/16" and pulled carbs cleaned and blew each passage with compressed air, it is still the same. once time I had the motor ran out of oil.
I wonder how to check the VRO pump. How to disable it so I can verify it by running pre mix in the tank. it idle fine when pressing linkage on the side of motor to rev it from mid range to wow it will stutering.
any advice will be apprecited.
