krazykooter
- Dec 3, 2015
- 20
Ok here is the list of things I've done to this motor...
1. Rebuilt carbs adjusted float so it's level with bowl when seen from upside down
2. Set the top needle at 1.5 turns out
3. Set the bottom needle at 1 turn out
4. Use 24:1 ratio twc3
5. Added fuel pump to single line instead of ole 2 line vacuum
6. Rebuilt the starter motor so it spins nice and strong resurfaced communitcator and used communicator oil on existing brushes now spins nice and strong...
7. Replaced electrical solenoid
8. Replaced motor head (blew 1st one threw a rod)
9. Added kill wires to respective points so when shut off position engine dies quickly due to shorting out to ground to kill spark
10. Add new packing for carb needles so they would not spin freely..
Ok now for what is happening engine will start when I spray gas into carb throat engine will rev high then keep going after a few mins but seems that the idle of it is non existent even when I adjust low speed needle.. I did not adjust high speed needle (lower one) at all when trying to fine tune to idle for shift speed... I've been taking apart this carb and engine about 5-10x's and I'm at my wits end on why doesn't it want to start without help of spraying into the carb why it doesn't seem to idle... My patience on get this baby running right is running thin... I've been researching these forums to see what I'm doing wrong... Please advise me where I may over look what I did do wrong...
