Hello Friends,
I just had this 1988 175xp installed on my boat replacing a Force Motor.
My concern is: It ran fine when I took it out Sunday. But, I did notice when
it was at "No Wake Speed", the Motor would Shake back and forth a little and it seems to have a small "miss" at lower idle speeds. The Marine shop that did the motor swap told me it has a small miss at WOT but it was really nothing to worry about cause they feel the motor just needed to be ran. I had them bypass the V Oil Pump so I can mix the gas and oil myself. 50.1
What would you do to try to fix this problem?
Marine Shop check it out and Compression is good and everything worked fine.
Thanks, Tim Myers
Staunton, Va.
Thanks, Tim Myers
Staunton, Va.
