odonus9999
- Jun 27, 2005
- 3
Got a 1980 Evinrude 150hp motor. Recently I noticed its been really hard to cold start as if the battery just does not have the power to turn over the motor - chug - chug etc. Even a new fresh battery does the same - chug - chug.<br /><br />I have stripped inspected and cleaned the starter motor and all is fine<br /><br />I suspect there is some restriction from preventing the motor from turning when cold. <br /><br />Note if you continue to keyon after say 30 secs - 1min the motor turns fires and no more problem....in or out of water.<br /><br />Took all plugs out and did the inspection and found all ok. Compression check all cylinders at 120 PSI - No3 did read 105 when cold but improved with oil. When engine run for 5 mins - rechecked all cycliners at 120psi.<br /><br />Now - I am assuming the restriction is possibly exhaust gas or ??? from not exiting the cylinder.<br /><br />ANy ideas as to what to check/inspect/try would be appreciated<br /><br />thanks<br />Aid
