Re: Evinrude 150 (low compression on 1 cylinder)
If you put oil in a cylinder, then take a compression reading-you will get false readings, higher than normal. Best to just let the suction of the carbs provide fuel/oil lubrication to the cyls. You could well have no spark on the bottom two cyls. The bottom carb could be all gunked up to the extent that it will not flow any fuel/lube to the bottom cyls-that might explain a low compression reading on one of the cyls. Or you could have an internal water leak that typically affects the lower cyls. Before you put any more money in it, I'd make sure the powerhead is not trashed. Pull the head with the low compression cylinder side and see what is going on. You may need to pull the side intake cover on that cyl to get a look at the side of the piston.
