i have a 1976 15hp evinrude.it was running ok but spark was arking off of time advance arm.i pulled the flywheel and found ground wire loose under flywheel.fixed that problem and now it is firing on both plugs but will not idle or run smooth.does the flywheel need to be torqed to a certain lbs could this be the problem.
