Hi,
I have a question regarding my 2001 1200 CC Bombardier. The engine died and I was offered an engine from a 2002 same size Bombardier. The difference I see is that the Bombardier with the good engine has the reverse on the side (manual) while the one with the bad engine is on the handle (electronic). They are both direct injection, 3 pistons and look exactly the same. Do you guys see any obvious reasons why this would not work or is the swap a straight forward process?
Thanks.
Thanks.
