I have a 2003 merc 4.3L with a 2003 merc alpha one drive. I am doing the normal maintenance on it and have changed the distributor cap,the ignition sensor and a new rotor sensor wheel. The problem is that the motor will not start or run. It trys to start but will not. I did have to take the hole distributor out and I did not move or start the motor at all it is still in the position it was when I put the new parts in. does anyone know what I did wrong.
