This is purely a question on theory
I would imagine an engine would run most efficiently at a certain RPM with the back pressure experienced from the exhaust. My 120HP exhausts from prop hub and the lower leg so I guess it has to turn over at mid to high RPM to build up the back pressure.
Does any one know if a variable (or fixed but of different size) exhaust outlet to water or to the free air would improve efficiency in these two strokes at lower RPM (or higher) reducing fuel consumption to what is currently considered normal?
