justthisguyyaknow
- Jul 13, 2009
- 38
Older starcraft boat with a 120hp Mercruiser, and a pre-alpha outdrive. I removed the engine to replace the coupler which was trashed by shifting into gear at a very high RPM (another post/another story). The engine is re-installed, and the hardware on the rear mounts is the double-wound springs and fiber washers, just like it should be.
I'm having a devil of a time aligning the engine for the outdrive, though. I finally removed the front mount, and switched to using a chain hoist so I can easily move the front of the engine up and down, just as a "proof of concept", planning to record the inclination of the valve cover from my inclinometer when I find the right spot.
At the sweet spot, I can get the alignment bar PART WAY in to the coupler (perhaps 1-1.5 inches), and no further. It's not a hard stop when pushing in, it feels like it binds up. The weird thing is that when I grease the bar, I am seeing even spline marks in the grease clear around the bar (the portion that makes it in), suggesting a good alignment. And yet, as I say, the bar won't go in all of the way (and it needs a good yank to get it back out), suggesting a bad alignment.
The spline marks show that I'm at the right spot, but the tool not moving in and out relatively freely shows that I am not. The tool IS going through the gimble bearing fine.
What could I be missing here?
