I want to be able to troll slower for flat water small lake fishing and am considering a transom mount electric trolling motor. I've never used one, don't know anything about them. The boat is a 16' flat bottom inflatable Achilles w/40HP outboard, probably 1000-1200 lbs under way. Minn Kota and Cabelas are offering some incentives on the variable speed Endura Max motors, and I need advice which one to get. I'm leaning towards the 55lb thrust model, but there are also 40/45/50 models. Cabelas is adding a $20 discount just to the 55 model. Looking at thrust recommendations, I'm wondering if the 55 is a good match? I don't want to end up with min speed still too high. Is there a good selection of prop pitches if I find I need to prop down some from the installed prop? I'm already at the lowest prop for the outboard, and still get 2 knots at min idle. I'd like to get down to 1 knot or even less. |
