Hi Guys I have a edge 24Volt 70 lb thrust trolling motor. My problem is it don't have enough go power LOL In calm water you have to run it on 3 setting to tell you are moving . this is a 17 ft fiberglass boat 70lb u should not have a problem on power.
if the wind is blowing may have to run on 4, then when when you put it on 5 it runs so fast you can hardly control it, Batteries are good just replaced one yesterday and charged system. All speeds work they just don't seem to be the speed they should be. Is this normal for a edge or do i have a problem! Cub48
