Re: Dumb Question ~ Heat Exchanger
The problem with heat exchangers is that you can only see half of the system. The closed part of the system is where you have to look and you can't. Pull off the end caps and see what it looks like,[as far as blockage. I wouldn't think the closed side would gunk up after 11 years, unleess someone was running mostly water and that water would have to be very hard [minerals]. You could take it to a radiator shop and have it boiled/rodded out For about 60 bucks or so. I would make sure my pumps were right first.......JK
