ADK_Boater
- Jun 29, 2010
- 217
Hey Everybody.
I have an '86 DT75 with power trim and tilt...at least it used to have power.
I bought it two years ago, and the power trim and tilt worked but sounded like it was weak...worked fine for about a year and half. I didn't know if that was the sound it normally made though.
At one point it made a pathetic sound and died (it still makes a weak sound but does not raise the motor).
I checked the fluid level periodically and it was always as full as the manual specified.
My question is should I have the unit rebuilt by professionals (there is a great shop that does quality work nearby) or should I buy a new aftermarket unit. Has anyone had experience with PTT rebuilds or aftermarket brands?
I've been getting in the water with a screwdriver to manually raise and lower the sonofagun. I hurt my back after the hurricane last fall so I don't think that is an option this year...plus the water is still cold enough to make you sing soprano.
Thanks for any suggestions!
