Is your driveshaft seal located above OR below your water impellor housing??? Going to change impellor and drive shaft seal out and cant locate it! Thanks
If it is what I am thinking it goes up top on the drive shaft. The little metal cup sits up and the rubber slides into it. You should see the seal is tapered to fit in the metal cup.
