Cj7jeepoffroad
- Apr 27, 2012
- 62
It looks like my drive is leaking oil when its trimmed in the trailer position, I'm going to pull it of and replace the drive shaft seals. I've read that some early alpha's have a spacer between the bearings alowing you to just torque the nut down, and some need to tightened to 10in/lbs bearing preload. Can someone shed some light on this?
Thanks
Thanks
