mudchuck
- Jul 29, 2016
- 61
Hi all,
I'm in the process of restoring a 1969 Starcraft V-hull.
So far I've pulled what appears to be some original decking and buoyancy foam out, and a piece that is newer with 2" blue board under it.
It looks as if someone did a repair to the front portion, but the back looks original and in bad shape.
Anyhow, the wood & foam are all out, and now I'm looking at aluminum that is in pretty good shape, just grimy. Hull is intact and amazingly no leaks.
I've searched this site and others but cannot seem to find anything close to what I'm about to ask. I'm wanting to install some kind of drainage tube down the middle under new foam boards and decking.
I'll post pictures soon, but for now, I'm looking for insight as to how to go about making sure I can drain the bottom, since the ribs have what looks like to way to get water past them to the rear where I could place a sump.
Anyone every notch the ribs to lay in a drainage tube?
