Hi ,
I got a Regal 2010 with 8.1 Gi engines and DPS drives.
For the last couple of months the starboard drive is trimming down less than it used to be.It used to reach minus 9 degrees , a month ago it started to reach just minus 7 and yesterday it could only reach minus 4.
I guess this must be due to lack of pressure in the trim cylinders, right? Should I check trim fluid level? or is there anything else to check ? (I did not see any fluid leak and trim motor does do the normal stronger noise it does when reachs the limits).
Thanks!
Thanks!
