Doelfins Effect On Small 14 Foot Boat
davio47
I have a 14 foot aluminum V with a 8 hp outboard on it . The motor I have came with a set of Doelfins. I have ran it without them on and it goes just nice. However, I do some splashing back of water from the shaft area at WOT. I was thinking of putting the Doelfins back on to see what effect it would have on the splash-back issue.
What effect would the Doelfins have on the running and turning performance of the boat if I put them on? Would it make the boat handle differently or would it be to responsive at WOT? Would it have no effect at all? Let me know if you have any thoughts on this. Thanks.:)
a70eliminator
Re: Doelfins Effect On Small 14 Foot Boat
There will no doubt be a difference, good or bad depends on the variables, weight distribution and motor tilt are the biggies.
davio47
I am going to give it a try in the morning just to see what the effects are. I just hope it doesn't make it unstable. I will let you know. Thanks:):)
davio47
Took the boat out this morning in the tidal marsh and did a little cat-fishing. Caught 3 nice ones. Anyway, the boat handled beautifully with the Doelfins on. It was very stable, handled and turned like on a rail. That was all good. It still didn't solve my splash-back issue at WOT. I will leave the Doelfins on though, I liked the way the boat handled. It did seem to lose a little top end. My back-splash issue will be another post. Thanks for your interest.
junior1113
where is cavitation plate in relation to bottom of transom? to me it sounds like motor should be higher on transom. motor mounted to low will create this also create uneeded drag.
davio47
You are right in your assessment on that. The cavitation plate is 2.5" below the transom, thus creating my back-splash issue. The motor is a short shaft but is slightly longer than the standard 15". I most likely need to build up the transom height or get another boat. Thanks for the response. :) :)
