Hello,
Getting ready to replace the plugs in my BE115GLEUA.
Quick question, the original engine manual says to use Champion QL82YC, while the OEM shop manual that you guys recommend I pick up says to use QL78YC. So... which one is correct?
The previous owner used NGK BPR7HS plugs, which actually have worked extremely well in the 3 times I've ran it since purchasing. No issues at all. Should I just replace it with those same ones?
