Re: dhadley help pls on 1986 140 evinrude
There's a couple of things that can happen with the spark under compression compared to not under compression. But you say it starts right up if you squirt fuel in so we assume the ignition is OK and it's turning fast enough. If it wasn't, it wouldn't start when you squirted fuel in.
Just to start with the basics, let's try new plugs on a cold start. I'm not sure that will do anything but we need to know. If that doesn't change anything we'll get back to the priming issue.
