Pulled my pickup assembly to replace anti siphon valve and check screen at the bottom. The rubber tube slipped some and when I reinstalled it the tube touches the bottom. There is a spring clamp where the rubber tube attaches to a plastic tube so I can adjust it My question is how far from the bottom of the tank should the bottom of the pickup tube be? I would assume you dont want it right on the bottom....john
