1980 Wellcraft 220XL. 21' and change. Deep V 22* to 24*ish. Nearly 5000# on the water with fuel and people and gear.
Mercruiser alpha I, 1.47 ratio, 350 V8 pushing near 300 HP.
Current prop is a turning point hustler 19" Al. Bought this prop as an inexpensive starting point. It is actually a pretty good prop. But...I need to get more hull out of the water, and she does not respond to trim well. Good out of the hole...pulls a 200# slalom skier no problem, and planes out very quick. Hull has a bit of factory hook in it, no doubt helping with the hole shot and time to plane. Would like to go to a stainless prop to help performance. Best numbers are 4600 rpm @ 52 MPH gps. The motor has a bit more to give but I need a prop to help. Looking for 4800 rpm and more top end.
Need the midas touch.
