Re: decabronizing
I consider it to be getting rid of the carbon built up in the engine from combustion processes. Too many deposits and the rings will seize in the grooves and build up will occur on top of the piston and the top of the head. Low temperature running and also high oil mix contribute to it.
You can do a decarbonise the longer way which is more thorough by dismantling the engine and soaking the pistons etc in a solvent or you can do a pretty good job by running seafoam through the fuel/carbs.
