Re: Crankcase swap?
I assume you blew up a 1996 p'head, and want to use a 1992 head on the existing 1996 midsection and leg....so,
It will all bolt on, but there are a couple of differences you should get serious answers on.
1. There will be some performance hit (maybe) because the 1996 is a finger ported piston/cylinder design, and the 1992 is not. You should really figure that out before bolting 1996 carbs on the 1992 block. The carbs are jetted differently, and designed differently. It may not be an issue at all...
2. The 1996 crankshaft splined end (lower end) has a stainless steel sleeve pressed onto the end that holds a captive o-ring for sealing the top of the driveshaft when all is assembled. The 1992 crank and matching driveshaft splines are designed with the o-ring slipped over the driveshaft. The o-ring sealing is done differently. The question is...is the 1996 driveshaft compatable with mating into a 1992 crank end?
3. You should be sure to move the intake manifild also as the 1996 is diamond shaped, while the 1992 is round at the throttle mounting surface.
There are differences......the experts will probably come up with more.
