As the title states, I'm new to fiberglass work. Finally got my resto project to the point where I am beginning to work on fiberglassing new stuff in. I did a coat of resin on the plywood I am using for stringers in order to seal it before I install it and start glassing it down. So far, this seems easy enough. My only question for now (more will certainly follow as I get further along in glassing) is, does the resin usually stay tacky for a few days? Its definitely adhered to the plywood just fine, the surface of it just seems tacky after 3 days. Enough so that if I lay some pine strips down to prop it up on, they stick to it when I lift it back up. If this is normal, no biggie, I can work with it as is. I just want to make sure I'm going about this right, and that I don't need to adjust how much hardener I am using or anything. Thanks for the help all!
Ryan
Ryan
