Hello, I've done much digging and not finding a lot regarding this topic. I have two 85 hp Chryslers. One is a 79 and the other is an 83 or 84. The 84 has great compression but no spark, the 79 has a bad center cylinder but great spark. I thought I could just put the motorola ignition system on the 83, but when I tried to mount the motorola stator, it hit the top crank bearing and remains about 1/8 above the crankcase. I looked at the presto stator housing and it has a shallower area that goes into the crankcase than the motorola housing does. I'm trying to convert mainly because the wiring on the 83 was hacked to heck, many wires were cut very close to the cd boxes. Any suggestions on which direction to go?
Thanks in Advance,
Joe
Thanks in Advance,
Joe
