angus63
- May 20, 2002
- 3,726
Re: Considering powering DOWN!!
I used cars as an analogy, but it was a technically poor choice. If the HP to RPM to MPH ratios are truly linear, than you are correct tippy. With different types of hulls (pad bottom, v bottom, pontoon, semi-displacement, displacement, foiled, etcc..) the relationships are not linear, hence the difference in throttle position to achieve the same rpm even though propped for the same WOT. Only at WOT (100% throttle position for all types) would the fuel consumptions be equal for the same rpm.
