Re: Considering Craiglist purchase of '75 25hp Evinrude longshaft
It's my least favorite johnson 25hp. It has a goofy, annoying ignition system with both an underflywheel coil and exterior coils. ALso, it has a stinky shallow drive system. If shallow drive is unimportant, and you don't mind redoing the ignition system, it's probably an o.k. motor.
Driver coil = $31.77
Ignition coil = $30.47 X 2
Total = about $90
I can get 2 coils for the older style ignition for about $12 apiece for a total of about $25. If one goes out, the other will get me home, since each cylinder's coil, condenser, and points work independently of the other. If the driver coil goes out on the '75 model ignition, you'll be paddling. I converted my '75 model back to the older style ignition because it's cheaper and I trust it more. I'm sure the '75 ignition is o.k., but I don't think it's as reliable as the older style.
JMO,
JBJ
