Re: Computer 24/7 below freezing....
Do shut down your monitors though, or allow it to go into low power mode. CRTs have a definite on time life-span, as do the available flat-screen technologies. Plus the CRT wastes a lot of electricity.<br />For what it's worth, my home computer is 24/7, running Prime95 which really heats up the processor. I think a lot of problems people have are with cheap power supplies - I've seen a number where the electrolytic capacitors dry out, go out of tolerance, and cause the computer to malfunction. Too many use 85° rated caps or really cheap 105° which can be worse. <br />As for cold, almost all hard drives are specified for use only 5°(C) above freezing so that could be a problem. I've never seen it personally but I'm sure there's a reason. Probably worried about the heads freezing to the platter or something. If left on and spinning, that won't be a problem.
