Re: Compression question:
Hi Gunner
Is the prop still in good shape? No nicks, bends, Etc? Might take a look at the throttle linkage and make sure it's advancing fully. The throttle plates should be horizontal when the throttle is wide open. Is the timing advancing fully? Just some things to check since the engine sounds healthy at least from a compression standpoint....Don't discount that it could be the boat causing problems, too...What kind is it?
